incredibad
First off I'm not sure if this is the right section of the forum to be posting this but i thought i would give it a shot. Its an OMC set up with a GM 350 5.7l. Its time for a rebuild on the motor. I was told to run marine gaskets in the engine and I was wondering how crucial this is as opposed to running normal automotive gaskets. Also, Will swapping in an aluminum intake and a better cam help out on the water? WOT is about 3k rpm or so, Id like to be able to give this thing a little more pep. I'm also toying around with the idea of swapping in a 350 diesel, anyone have any ideas on the matter?
