I winterized my Merc 4.3 myself this year. I followed the 3 point manual drain instructions in the manual. I am now finding that the manual is incorrect and there are 5 drain points. (previous feed indicates others have had that problem) When I started it last week I found 4 freeze out plugs had pushed out (2 on each side). I have several questions:
1) Has anyone else had this problem and gotten any help from Mercury? It is a 2006 with 115 hours out of warranty.
2) What are the chances of the block being cracked? Before I go to the trouble of replacing the freeze out plugs - is there anyway to tell?
3) Is it possible to replace them without pulling the engine? I believe with a cherry picker I can secure the front of the engine to remove the motor mounts one at a time to replace the one behind it. I assume I will have to remove the starter which does not look too easy to replace the one behind it.
4) I drained the water plug in the front and the 2 on the sides toward to front - like the manual said - I believe I read there are 2 freeze out plugs in the front. I cannot see them anywhere. I assume they are behind some of the bracketing on the front. If there are 2 on the front can I assume they are alright since the front was drained?
5) Are there other types of freeze out plugs that install and expand by tightening? If it is determined I can replace them with out removing the engine - there is not a lot of room to tap them in.
Any advise or opinions are greatly appreciated. As you can tell I am in dire need of advice.
Sincerely, Larry Edwards
