MarineEngine.com - Your online store for all types of marine engines and boat parts.
Order by phone
(800) 209-9624
Monday - Friday
8:30 AM - 5:30 PM EST
Safe Online Orders
Comodo Enhanced Security
Special $9.95 Flat Rate Shipping
Boat Repair Forum Boat Repair Forum     Boat Video Gallery Video Gallery
Home | Contact | Shipping | Returns | Cart View your shopping cart.
Part Number Search
Shop by engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Click for Johnson Evinrude Diagrams, Parts and Manuals!
Results 1 to 3 of 3
  1. #1
    Default 1955 3 hp Johnson Sea Horse JW-11
    Hi,
    I have an oil leak from the lower unit. It has NEVER been opened. I suspect it needs a new bearing housing seal. Any other thoughts of what it could be or is there anything I should replace while I am in there? Any tricks to installing or assembly?
    Thanks.
  2. #2
    Join Date
    May 2008
    Location
    Kent, the garden of England, UK
    Posts
    1,150
    Default Re: 1955 Johnson Sea Horse 3hp JW-11
    You are sure it is gear oil leaking out and not just unbunt oil from the fuel.
    Is there any water in the oil?
    If you go there to do the seals you might as well do them all #9 #22 and #19 and the washer(s) on the oil fill screw(s)
    Also overhaul the water pump while you have it accessible.
    http://www.marineengine.com/parts/vi...7639900001.htm
  3. #3
    Thanks for the reply. I am sure it is a leak. I will go ahead and replace those seals and pump.
Similar Threads
  1. 1955 5 horse Sea King
    By bait_troller in forum Montgomery Wards Sea King
    Last Post: 09-24-2009, 12:28 PM
  2. Need rewind pull starter unit that goes on my 1955 75 horse evinrude
    By sophie in forum Johnson Evinrude Outboard Archive
    Last Post: 06-25-2009, 02:34 PM
  3. 1955 evinrude 15 horse fastwin model 15014
    By wombat in forum Johnson Evinrude Outboard Archive
    Last Post: 06-18-2008, 02:25 PM
  4. Timing a 1955 johnson 25 hp sea horse
    By walchorn in forum Johnson Evinrude Outboard Archive
    Last Post: 08-03-2007, 07:31 PM
  5. 1955 25hp Johnson sea horse
    By craig303 in forum Johnson Evinrude Outboard Archive
    Last Post: 07-09-2006, 10:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
