Results 1 to 5 of 5
  1. #1
    Default Power Trim Electrical Issue 2002 50 hp
    I have a 2002 Merc 50 three cylinder.
    The power trim lifts the motor fine but the down is not working.
    I thought it was a bad relay so I replaced them.
    Problem still persists -- will go up but not down.
    If I pull the blue & green wires and jump direct from the battery I can make it go up/ reverse the wires and it goes down fine. So I know it's not the trim motor.
    Could I have a bad ground after that relay? Schematic shows ground to the chassis but where in reality I can't see.
  2. #2
    Join Date
    Dec 2009
    Rineyville, KY, U.S.A.
    Default Re: Power Trim Electrical Issue
    could be a ground, or it could be a bad trim switch.
  3. #3
    I had thought about the trim switch, but if I reverse the blue and green wires leading to the trim motor and then push the button for up the motor goes down. So it appears the switch is good.
  4. #4
    Join Date
    Dec 2009
    no, if you reverse the wires, then the switch is not making contact when you push down. replace the switch.
  5. #5
    AHHHHH! So true!
Similar Threads
  1. Bravo power trim issue 2000 5.7
    By ayleeuss in forum Mercruiser Sterndrive Forum
    Last Post: 02-10-2010, 10:39 PM
  2. 2004 Yamaha 40hp Electrical Issue Burnt No Power
    By riverfisher in forum Yamaha Outboard Forum
    Last Post: 01-30-2010, 09:51 AM
  3. Electrical issues with 2002 150 HP
    By walleye99 in forum Johnson Evinrude Outboard Archive
    Last Post: 07-19-2008, 03:47 PM
  4. 1991 43L Mercruiser No electrical power except trim
    By jimbo66 in forum Mercruiser Sterndrive Archive
    Last Post: 06-29-2008, 08:14 PM
  5. Power trim issue
    By jenx in forum Mercury Mariner Outboard Archive
    Last Post: 10-05-2006, 11:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
