Results 1 to 4 of 4
  1. #1
    Default 1969 johnson 55hp 3cyl. no spark
    I have a 1969 3 cylinder 55 hp johnson that has no spark on any of the 3 spark plugs, where do I start to troubleshoot?
  2. #2
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,309
    Default Re: 1969 johnson 55hp 3cyl. no spark
    (Point Setting Of Battery Capacitance Discharge)
    ( Ignition Models - 1968 thru 1972)
    (Some have points - Some do not)
    (Joe Reeves)
    The points must be set to .010 but no wider than .010..... BUT in some instances due to a possible slight inaccurately machined crankshaft lobe or a slight offset of one set of points, a setting slightly less than .010 would be required as follows.
    Whether the crankshaft has two or three lobes, when setting the points, check the setting of the points on each individual lobe by rotating the crankshaft by hand.
    You may find that setting one set of points to .010 on one lobe, then turning the crankshaft to the next lobe, the gap measures .011 or .012 (too wide). This is where you would need to close that gap down to the required .010. A gap too wide can result in a ignition miss when throttle is applied.
    Bottom line, pertaining to the point setting at the various lobe locations____ .010, .010, .009, is okay____ .010, .010, .011 is not!
    Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
    http://stores.ebay.com/Evinrude-John...tc?refid=store
    (Voltage Drop To Battery Capacitance Discharge)
    ( Pulsepack When Electric Starter Is Engaged)
    (J. Reeves)
    On the older Battery Capacitance Discharge ignition systems (1968-1972), the electric starter reaches a point, even with a top notch battery, whereas the starter will draw excess voltage/current/whatever which results in a voltage drop to the pulsepack. The cure is to purchase a diode which is capable of handling 12 volts and installing it between the starter terminal of the starter solenoid (NOT the battery cable terminal) and the wiring terminal that supplies voltage to the pulsepack.
    The diode must be installed so that the current flows from the starter terminal of the solenoid to the pulsepack... NOT vice versa. When that diode is installed in this manner, when the key is turned to the start position, the voltage that is applied to the starter is also applied directly to the pulsepack via the diode effectively eliminating the voltage drop and energizing the pulsepack with the required voltage needed for its proper operation.
    (Battery Capacitance Dischage Powerpack Test)
    Various OMC Engines - 1968 to 1972)
    (J. Reeves)
    Purchase a small 12v bulb at your local automotive parts store (the 12v bulb is to look like a flashlight bulb, not a headlight bulb). Solder two wires to that bulb, one to the side of the bulb (ground), and the other to the positive point. You might use a bulb of a somewhat lower voltage to obtain a brighter glow... just a suggestion.
    Remove the spark plugs. With the key in the on position, make sure that you have 12v going to the pack at the terminal block (purple wire). Now, connect the ground wire from the bulb to any powerhead ground. Connect the wire from the positive point of that bulb to the powerpack wire that is connected to the coil wire on the terminal board (blue wire).
    Crank the engine and observe that bulb closely (CLOSELY!). If that bulb glows even the slightest bit, the powerpack is okay. It may be a very dim glow... just so it glows! If it doesn't glow, the pack has failed.
    Keep in mind, that type powerpack (Battery Capacitance Discharge) demands a top notch battery of at least 70 amp hours. Any less will, in time, cause powerpack failure.
  3. #3
    Thanks for the reply, I will try some of the troubleshooting ideas. One other thing, The battery was connected overnight, and was completely dead the next moring, someting was drawing it down overnight! The battery is new and was at full charge!
  4. #4
    Join Date
    Feb 2001
    Location
    Posts
    14,309
    Disconnect cables from positive terminal of battery, connect a volt meter or amp meter between the positive battery terminal and those wires. A drain will show irself in the form of having the meter register. Start disconnecting wires from components until the meter suddenly drops to a zero voltage....... indicating you found the faulty component.
Similar Threads
  1. 1969 55hp johnson engine gets pressure locked
    By bloom in forum Johnson Evinrude Outboard Archive
    Last Post: 06-07-2009, 08:00 AM
  2. 55hp Johnson 1969
    By gp14 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-21-2009, 11:32 AM
  3. 1969 Evinrude 55HP 3 cyl spark only sometimes
    By thommo in forum Johnson Evinrude Outboard Archive
    Last Post: 03-29-2008, 08:23 PM
  4. 1969 55 johnson no spark
    By jrocply841 in forum Johnson Evinrude Outboard Archive
    Last Post: 07-13-2007, 11:15 PM
  5. Johnson 60hp 3cyl Spark Plug Help
    By gearhead in forum Johnson Evinrude Outboard Archive
    Last Post: 04-25-2007, 07:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
