Results 1 to 6 of 6
  1. #1
    Default Evinrude 140hp 1979 Fuel / Oil Ratio
    Hi,
    Ive just purchased my first boat complete with 1979 140hp Evinrude engine. good news however im stuck regarding the fuel to oil ratio.
    Do anybody know what the fuel to oil ratio is? The previous owner stated that is 20:1 but on a website i found a ration of 50:1, does anyone know or where i will be able to find out??
    Im new to this and not very technical so what will happen the ration is incorrect?
    Any help / advice would be very useful.
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    Default Re: Evinrude 140hp 1979 Fuel / Oil Ratio
    They all run on 2% or 50:1.
    For normal use, not more nor less.
    Use any TCW 2 (for mix in fuel) or TCW3 (Both mix in fuel and/or separate oil-tank) oil.
    If planning to do your own service, invest in an original OEM workshop manual as well.
  3. #3
    Join Date
    May 2008
    Location
    Kent, the garden of England, UK
    Posts
    1,200
    At least since 1964!
    That's near enough 1 pint in 6gallons.
    It includes engines produced in 1985 and a few years thereafter that were originally marked for 100:1
    At 20:1 it will smoke excessively and might well foul its plugs.
  4. #4
    Join Date
    Apr 2006
    Location
    Posts
    5,750
    Quote Originally Posted by vics View Post
    All with roller/needle bearings on cranks and rods.
    Not only will 20:1 foul the plugs, but carbon up rings and exhaust in short time. That might be quite expensive!
  5. #5
    hi paul new too boats but my 1979 150hp evinrude had it printed on air box and it was 50to 1 ratio hope this helps
  6. #6
    Join Date
    Dec 2010
    Location
    Big white NE house with black shutters
    Posts
    126
    The 100:1 ratio was for a short time because it failed and created pre-mature failure. Even motor's marked 100:1 should be run at 50:1
Similar Threads
  1. Fuel problems with 1977 140hp Evinrude
    By H-Town Cobra in forum Johnson Evinrude Outboard Forum
    Last Post: 06-06-2010, 11:15 AM
  2. Fuel Mixture 1977 140hp Evinrude
    By H-Town Cobra in forum Fuel / Oil Mixture Ratio
    Last Post: 05-08-2010, 07:17 PM
  3. 1979 evinrude outboardnoPeeing out the back and oil ratio
    By jason hughes in forum Johnson Evinrude Outboard Archive
    Last Post: 05-28-2006, 03:17 AM
  4. Oil Ratio for a 1979 Evinrude 99HP
    By termie in forum Johnson Evinrude Outboard Archive
    Last Post: 04-23-2003, 05:24 AM
  5. Fuel Everywhere 1978 140HP Evinrude Outboard
    By danjmartin in forum Outboard motors archive 2000-2004
    Last Post: 09-11-2001, 11:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
