Click forPleasurecraft Marine parts and manuals!
Results 1 to 13 of 13
  1. #1
    Default 1987 pcm 4140 where can i order parts
    I have a 1987 PCM 4140 believe a mitsbishi engine. I need to order parts. Anyone tell me where I can get a parts list and/or where i can order parts. Thanks
  2. #2
    Join Date
    Sep 2006
    Location
    SF BAY AREA, CALI, USA
    Posts
    8,649
    Default Re: 1987 pcm 4140 where can i order parts
    what do you need?
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
  3. #3
    Depends upon what you are looking for! I have generated a list of Vendors and numbers. I could email you a file. I have a set of 1988 Mitsubishi 4 cyl 4140's, 140 hp. Great running, recently rebuilt. Though accessory parts are becoming a problem. Be careful w/ distributor if its a Mallory system. No longer made, and to my knowledge, no cross over! Have become pretty familiar with these engines.
    Give me a call if you like!
    Bruce 401-323-1099
  4. #4
    Hey Bruce. Can I get the vendor list? I jist bought a clean 87 sunliner and need outdrive parts n driveshaft. Thanks
  5. #5
    Found what I need to build my own driveshaft now I just need the big boot that goes over the shaff from the trans to the outdrive. Any help would be appreciated
  6. #6
    found a complete parts boat if anyone needs parts. i took the driveshaft, boot, and transmission. all else ill sell parts or complete boat, motor, ect including trailer! call me at 623-742-8166 Randy
  7. #7
    I have broken the steering arm on my 87 and am looking for a replacement, I would be interested in the steering arm and steering cable off your parts boat if you still have them, I could also have the splined pin to hold the steering arm on just in case mine is worn.
  8. #8
    I broke the steering arm but have located one,
  9. #9
    Join Date
    Sep 2006
    Location
    Posts
    8,649
    Default
    Quote Originally Posted by Donald Cobb View Post
    There are tons of companies that make that stuff
  10. #10
    Quote Originally Posted by randynier70 View Post
    I am looking for an exhaust manifold for my PCM 4140 that I am rebuilding. I am having a hard time finding one. Please let me know if you know where I can find a new or used one. Much appreciated! JON 541-379-9034
  11. #11
    I have two 1987 Sunliners that I will part out if there is enough interest. One is a decent boat that is complete with a bad trans. The other ahd a blown eng but has several good parts. Joey 864-630-70 seven six.
  12. #12
    Join Date
    Sep 2006
    Location
    Posts
    8,649
    Yes they do not have them if you get me a part number I can locate one for you
  13. #13
    HELP....just had the exhaust manifold go bad on my 4140. Does anyone know where I can get one?
    Thanks Steve...
Similar Threads
  1. need to know what motor to order parts 1984 305
    By sticky in forum Volvo Penta Gas Engine Forum
    Last Post: 04-06-2010, 10:04 AM
  2. 1987 PCM MITS 4140
    By thomasj29108 in forum Pleasurecraft Marine PCM Forum
    Last Post: 10-16-2009, 08:53 PM
  3. Johnson GT 150 1987 cylinder order
    By marineman43 in forum Johnson Evinrude Outboard Archive
    Last Post: 09-07-2009, 05:58 PM
  4. 1987 43L V6 DIST CAP FIRING ORDER
    By terrien4t in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-27-2006, 08:58 AM
  5. Firing order volvo 23 1987
    By em8888 in forum Volvo Penta Gas Archive
    Last Post: 06-10-2006, 09:05 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
