downwindtracker2
I replaced the prop shaft seal,as it had leaked,and bearing when I was putting together one 7.5 from two,a '75 and '76. After adjusting the idle in a barrel,I have one inch oil spot under the leg in the garage. This is the second time I've had this. This doesn't seem normal. I didn't feel a groove on the shaft when I installed it. I put the lips to the inside and filled them with grease. I didn't have new fiber washers for the fill and vent screws so I used some white teflon sealant,Locktite # 597. What did I do wrong? thx
