Firstly Iam a newbie
I have a 1973 28'fiberform boat with two 250 merc inline 6 cyl. 165 hp motors.Alpha one legs
I recently had both legs worked on because of water in the oil. After the boat was put back in the water one side works fine. will run the boat at 13 knots @4000 rpm by its self however the other motor/leg will rev to 4000 but will only push the boat maybe 3 knots. The mechanic says maybe the props not big enough or the exhaust may be plugged on that side. Both legs have the same props. This boat is new to me and as far as the survey says she should go 28 knots top speed and 20 cruising.
Is it possible the exhaust is the problem?
Identical motors and legs and one side barely moves the boat.
Any Ideas?
Any Ideas?
