"I have a 1978 Mercruiser that
"I have a 1978 Mercruiser that was in storage for quite some time. Engine was rebuilt and run only a few times before being stored. I drained all the old fuel, flushed and dried fuel tank, replaced fuel pump, replaced check valve at tank, had Rochester Quadrajet rebuilt, replaced coil, plugs, points, condensor, cap, rotor and wires. The problem I am having is that when I put the boat in the water, it runs fine until I throttle up. After about five minutes, it just stalls and I have to let it set for a good ten minutes before it will start again and then it will only run up to about 1000 RPMs. It feels like it is starving for fuel but there is still fuel in the carb. Any suggestions?"
