"1982 75 hp Johnson was idling
"1982 75 hp Johnson was idling fine but would fall on it's face when placed in gear in the water. After rebuilding the carbs and with the problem remaining, I pulled the intake off to check the reed valves. I also pulled the flywheel to check the timer base.
After breaking down and cleaning the carbs (again) I cleaned off the old gasket, applied a new one and installed the intake manifold and then the carbs.
With everything assembled I went to fire off the engine and it will not start. I am getting solid spark over each cylinder. The engine will consistantly backfire during the first few cranks.
I did NOT touch the linkage and have verified all three carbs throats are synchronized.
I have not yet put a timing light to it, but I am really scratching my head as to what I could have distrubed.
Am I overlooking something very simple here? Your thoughts are greatly appreciated. Thanks!"
