How to remove prop shaft
buzzyb
can someone tell or show me ho
can someone tell or show me how to remove the prop shaft from my yamaha p150tlrt.
thanks
I have a c90 yamaha bent prop shaft. Ordered new one from boats.net and got a clymer manual from( the manual store.com) On mine I had to remove lower unit,remove prop,then carefully remove shiftshaft,then prop shaft assembly. I would surely get a good manual,and if you have got mechanical skills this should be no problem.If you do this yourself replace any seals,o rings and gaskets that you disturb.hope this helps.
Took off the prop and rear seal but I did not lemove the lower unit from motor. Is that necessary to remove the shaft and gears?
