"re: "my motor is a 85 nev
"re: "my motor is a 85 never had one, lived in saltwater all it's life.
I flush it after every use, oh it has the original mani also.
I know you'all are gonna jump on me, just pointing out a fact here.
If the motor had one from the factory then i would say maintain it, but to install one naa my own personal opinion is all."
No.. I'm not going to jump on you. Several years ago my wife and I bought a 1969 Chriscraft Lancer that had spent all its life in salt water, raw water cooled. The owner had installed a fresh water flush and was compulsive about using it. When we bought it in 2004, it ran like a top, but no longer had its original elbows/manifolds. We replaced the engine with a new FWC 350CID Merc in 2006 with thru hull filter wedge water pickup and flush port. Still flush the system on a regular basis to prolong the life of the elbows, mostly.
FWC had another often overlooked benefit. In salt water the T'stats in raw water systems are limited to 140 degrees, which is not really warm enough to keep an engine "happy". My FWC system runs at 180 degrees. Running at the higher temp gives better fuel economy as well as allowing the oil to get to its design temp (and purging moisture)."
