Click for Suzuki Manuals, Parts and Model Guides!
Results 1 to 13 of 13
    Default 2007 Df 115 hp one beep when starting motor
    ive had a 2007 df115 since new and today when i started it i had a short beep when the motor was kicking over. it started fine. the motor done this every time. its not the service alarm and none of the lights are coming on to indicate a problem. i gave the motor a once over but could not see any problems
    Default Re: Df 115 one beep when starting motor
    hi aaron,
    my 2007 df115 is now doing the same thing!!.... was wondering if you had found what the issuse is?
    Sep 2010
    ontario
    14,138
    Most motors these days give a momentary beep when the key is turned " on "--------------------a self check of the horn.
    the motor beeps when turned to the on position doing its normal checks. then it gives another beep when the motor is turning over to start. has only started doing this in the last 2 weeks. got me stumped?!?!
    Sep 2006
    SF BAY AREA, CALI, USA
    8,649
    if you have 10hrs or 100hrs its the oil alarm
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
  6. #6
    Feb 2010
    Newport News, Virginia, USA`
    34
    The oil change reminder is a flashing oil light. I am not aware of an associated beep, but if it is the oil change reminder you should also have the flashing oil light. The reset procedure is in your owners manual.
  7. #7
    Sep 2006
    8,649
    oh it beeps
  8. #8
    Default Re: 2007 Df 115 hp one beep when starting motor
    It definitely beeps to remind you you need in oil change. You can clear it so it stops beeping by pulling your lanyard on the kill switch, and pulling the knob 3x within 10 seconds. I almost had a heart attack the first time it came on.
  9. #9
    Sep 2006
    8,649
    its 3 times in 7 seconds, LOL
  10. #10
    3/7 ratio is absolutely correct capitan!
  11. #11
    Sep 2006
    8,649
    yep, i work on these daily, LOL
  12. #12
    fine... but by mistake or by practicing purpose do not repeat the procedure otherwise you will not hear the next service alarm.
  13. Default Re: Df 115 one beep when starting motor
    What does it mean if i turn the key and it doesn't beep. That happened to one of the boats I take care for a couple days but now it beeps again? Thanks Justin
  1. Starting cold 2007 etec 150
    By darrin in forum Johnson Evinrude Outboard Archive
    Last Post: 03-29-2008, 05:21 AM
  2. 1995 150hp carbs leak beep beep
    By going2freak in forum Johnson Evinrude Outboard Archive
    Last Post: 11-20-2007, 12:01 PM
  3. 1991 60 hp 2 stroke beep beep beep
    By karlow in forum Johnson Evinrude Outboard Archive
    Last Post: 10-21-2007, 08:52 AM
  4. Beep beep oil warning 150 hp 1997 offshore
    By tgmcree in forum Mercury Mariner Outboard Archive
    Last Post: 03-09-2007, 03:20 AM
  5. Johnson 90hp b82b Motor has a constant beep above 3000rpms
    By Mr Beep in forum Johnson Evinrude Outboard Archive
    Last Post: 05-02-2004, 07:35 AM
