88hp110hp assembling
pwolf
"I’m in the process of swappin
"I’m in the process of swapping the electrical & carbs from a 1994 88hp to a rebuilt 1989 110hp block, however I have completed assembling and have found a port that was not on my 88hp does this need to plugged and what is this connection?
"that item,is the pulse limite
"that item,is the pulse limiter,...its the vacuum source,for the VRO equiped engines...plug it."
"Yep, what JWB said. I'd a
"Yep, what JWB said. I'd add that it's best to remove it and use a brass pipe threaded fitting to plug."
