Click for Volvo Penta manuals!
Results 1 to 4 of 4
Thread: What Duo Prop
  1. #1
    Join Date
    Feb 2010
    Location
    Ireland
    Posts
    3
    Default I have a 1988 24ft. sea ray so
    I have a 1988 24ft. sea ray sorrentoI know they way 1.75kg with a mercruiser engine but mine has a heavier volvo penta kad 43 diesel 230hp and is more torqueier.What would the best aluminum props be for my leg?
  2. #2
    Join Date
    Jun 2009
    Location
    Akersberga Sweden
    Posts
    32
    Default "Brian, What stern drive do
    "Brian,
    What stern drive do you have? DP-?, gear ratio?
    Martin"
  3. #3
    Join Date
    Feb 2010
    Location
    Ireland
    Posts
    3
    Default "I have a DPE 1.95-1.I current
    "I have a DPE 1.95-1.I currently have B5s on as I think they would be recommended with the engine, but it is powering a small hull."
  4. #4
    Join Date
    Jun 2009
    Location
    Akersberga Sweden
    Posts
    32
    Default "Brian, I think that the B5 i
    "Brian,
    I think that the B5 is to small for your boat, your engine should go up to 3900rpm on full trottle, but I think you will easy reach 4000rpm with B5, depending on how easy you reach 3900, you should go for B6 or even bigger, to go from B5 to B6 reduces the RPM with app. 300prm.
    It is difficult to recomend, you must test, the sea whater temp is also of interest, if it is hot you will not get full power out of your engine, and then B5 can be OK, it is important that the rpm reaches minimum 3700 on full trottle, but not over 3900."
Similar Threads
  1. Duo prop to single prop question
    By glastron24css92 in forum Volvo Penta Gas Archive
    Last Post: 07-23-2009, 12:39 PM
  2. Prop install and prop size
    By birdy916 in forum Mercruiser Sterndrive Archive
    Last Post: 06-10-2009, 07:20 AM
  3. Volvo Penta Duo Prop DPS Prop Installation
    By njfishing in forum Volvo Penta Gas Archive
    Last Post: 04-30-2009, 10:05 AM
  4. New Prop maybe
    By jazzyj in forum Mercruiser Sterndrive Archive
    Last Post: 12-12-2006, 06:10 AM
  5. Trying to determine diameter and pitch of prop on 85HP Johnson from number stamped on prop
    By Bob Padowicz in forum Johnson Evinrude Outboard Archive
    Last Post: 07-29-2006, 11:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
