"I got out a micrometer and th
"I got out a micrometer and thread gage and this is what I found:
Fuel pump, both inlet and outlet: 1/8-27 tapered pipe thread.
Solex 44PA1 Carbs- fuel inlet: M8x1.25 banjo fitting.
My objective is to make up new fuel lines using AN fittings, and I've found most, but not all the necessary hardware.
These folks sell -3 AN to 1/8-27 NPT adapters which would be mounted to the fuel pump ports:
http://www.russellperformance.com
These folks sell 8mm banjo fittings needed at the carbs. They appear to be brake fittings but I don't know why they wouldn't be fine on the carbs:
http://www.bonacoinc.com
I have an inquiry in to Bonaco about availability of the following:
-3 AN to 8mm banjos
M8x1.25 banjo bolts
and either:
-3AN to 8mm double banjo
or:
Double M8x1.25 banjo bolts
These last 2 items are needed to send fuel to the "second" carburetor from the fitting on the "first" carb to receive fuel from the fuel pump.
I didn't bother posting anything about fittings on the fuel tank and shut-off valves, etc. as those would be peculiar to the boat in question. My boat (Coronet) was built in Denmark, so it might be metric, and it might be NPT- I haven't looked yet. If I find the rest of the hardware, I'll post sources here. Hope this helps others who want to replace old fuel lines."
