"I rebuilt the fuel pump and c
"I rebuilt the fuel pump and cleaned the carburetor. It will not start unless I squirt some fuel mix in the intake. The bulb stays hard.
How much pressure should the fuel pump build up? I can hold my finger over it and stop the fuel flow. The fuel doesn't squirt very far out when cranking the motor (hose off carburetor and pointing up).
Shouldn't the carburetor bowl empty when I crank the motor? Since the bulb stays hard is the fuel pump ok?
Thank you,
Bill"
Thank you,
Bill"
