Click for Honda Manuals, Parts and Model Guides!
Results 1 to 2 of 2
  1. #1
    Join Date
    Feb 2010
    Location
    portland, or,
    Posts
    1
    Default "after winter storage, i fired
    "after winter storage, i fired up the motor it started right fine, however no water came out so i shut the motor off, i started it again later but still no water so any thoughts or.........
    thanks, brad"
  2. #2
    Join Date
    Nov 2009
    Location
    temecula, ca., usa
    Posts
    2,714
    Default "Depending on how many seasons
    "Depending on how many seasons are on the pump, normally it should prime up and deliver water in a very few seconds. If it was just recently replaced, then I would first rule out any blockage in the tell-tale tube, nozzle or passage before condemning the pump. It could be something as simple as a spider decided to make a home in there. If the pump is any older that a season or two, then I would service the impeller anyway as that is just the price of going boating.
    Those impeller vanes don't like setting all curled up in that housing for an extended amount of time or useage before becoming brittle and breaking. Allowing an impeller to age like wine will only bring you more complex problems as it starts to disintegrate and pieces get into places you don't want them."
Similar Threads
  1. 5hp stopped shifting BF5A
    By lucky_bum in forum Honda Outboard Archive
    Last Post: 07-31-2008, 10:39 AM
  2. Honda BF5A with idle problems
    By hawksbill in forum Honda Outboard Archive
    Last Post: 06-27-2008, 11:11 PM
  3. Honda BF5A Water Pump
    By kmp in forum Honda Outboard Archive
    Last Post: 04-04-2008, 07:53 PM
  4. BF5A water impeller grommet Justintime
    By cosmosailer in forum Honda Outboard Archive
    Last Post: 03-13-2008, 11:42 PM
  5. Removal of lower unit on BF5A
    By Bill Coogan in forum Honda Outboard Archive
    Last Post: 10-24-2007, 08:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
