Shear Pin1988 25 hp
No shear pin. If the prop is s
No shear pin. If the prop is slipping it will have to be re-hubbed by a prop shop or replaced.
Son used last. He claims motor
Son used last. He claims motor ran great just
wouldn't push boat. It is the original prop.
I'll check hub. Thanks
"Make a scribe mark on both si
"Make a scribe mark on both sides of the hub, then run the motor. If the scribe mark moved, replace the hub.
Jeff"
