Click for Volvo Penta parts and manuals!
Results 1 to 11 of 11
  1. #1
    Join Date
    Jul 2009
    Location
    Knoxville, Tennessee, USA
    Posts
    56
    Default 1984 AQ125 A Timing Belt
    Going to change my Timing belt this season and was wondering if this is the correct "Automotive" equivilent for my 1984 AQ125 A??
    1984 Volvo 242 DL 4 Cyl 2.3L
    Join Date
    Oct 2008
    Location
    Lakewood, NY USA
    Posts
    317
    Default "Casey, your engine aq125a
    "Casey,
    your engine aq125a is a 2.1L. and that would be out of the same year and make Volvo car but with the 2.1L motor not the 2.3L motor.Im pretty sure
    that the 2.3L is the aq145a but Im not 100% on that one.Im sure when Ricardo or EL.P see this post they will give you the correct answer to your question.Good Luck"
  3. #3
    Join Date
    Jul 2009
    Location
    Salem, OR,
    Posts
    286
    Default "Any reason that you don't
    "Any reason that you don't want to buy the belt from Volvo-Penta? I would think that just ordering the right part would be easier than guessing. It's VP P/N 463377, called a "tooth belt". List price is $45.33 USD. Sierra P/N is 18-4029."
  4. #4
    Join Date
    Feb 2006
    Location
    Ladysmith, BC, Canada
    Posts
    5,862
    Default "Casey P, that one will work.
    "Casey P, that one will work. In case of doubt, ask for a Dayco DY95032 timing belt or equivalent."
    [URL]http://www.grandmaraismichigan.com/Recreation/fisherman.gif[/URL]
  5. #5
    Join Date
    Jul 2009
    Location
    Posts
    56
    Default "El, thanks for the info. J
    Joe Merchant, The reason I'm not buying VP is cost. Going automotive I can get the belt and tensioner for $35.00."
  6. #6
    Join Date
    Feb 2006
    Location
    Posts
    5,862
    Default "You are welcome, Casey P. In
    "You are welcome, Casey P. In fact, there is no difference between automotive and marine regarding belt and tensioner. Same applies to timing gears."
  7. #7
    Join Date
    Aug 2006
    Location
    Gainesville, Georgia, USA
    Posts
    31
    Default Re: AQ125 A Timing Belt
    I buy all my VW parts from Autohausaz.com
    They also have my Volvo boat parts! Here is the timing belt stuff: http://sd.autohausaz.com/autohausaz/detailw.jsp?sid=uvgai445lxqlcc55cgch1n45&partner=a utohausaz&year=1982&make=27&[email protected] ,%20Normal&category=timing%20belt∂[email protected]%2 0Belt%20Kit
    They only sell top-notch german and american parts.
  8. #8
    Join Date
    Jun 2010
    Location
    spokane
    Posts
    20
    Hi guys I too am looking for the correct auto parts for my aq140a I lost the timing belt on it this weekend. Would the dayco dy95032 be the same for me? Also does any one have a parts # for the tensioner? What auto engine is this based from? I would like to just be able to grab all this stuff from Napa! Thanks for the help!!
  9. #9
    Join Date
    Feb 2006
    Location
    Posts
    5,862
    jibbs, the AQ125A and the AQ140A are the same engine block (B21), so timing belt and tensioner are interchangeable. The equivalent car would be a 1976-1982 242 Volvo.
    Go to www.autopartswarehouse.com, then select the above model and search for the components you need (tensioner, belt, etc).
  10. #10
    Join Date
    Jun 2010
    Location
    spokane
    Posts
    20
    Great I'll check there! Thank you..
  11. #11
    Join Date
    Jan 2012
    Location
    Ellis Kansas
    Posts
    43
    Default Re: 1984 AQ125 A Timing Belt
    AQ125a and AQ125b the same in this issue?
Similar Threads
  1. Timing Belt
    By stairwaytoseven in forum Honda Outboard Forum
    Last Post: 02-01-2011, 12:02 PM
  2. Timing Belt AQ 125
    By olddawg in forum Volvo Penta Gas Engine Forum
    Last Post: 08-14-2009, 05:56 PM
  3. FUEL PUMP FOR 1984 BAYLINER AQ125
    By bad_juju in forum Volvo Penta Gas Archive
    Last Post: 07-28-2009, 12:27 PM
  4. Timing Belt
    By david_f in forum Volvo Penta Gas Archive
    Last Post: 10-30-2008, 05:14 PM
  5. Timing belt
    By fixitman in forum Volvo Penta Gas Archive
    Last Post: 06-09-2008, 07:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
