MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 3 of 3
  1. #1
    Default "Hello all, new to site. I hav
    "Hello all, new to site. I have a 20HP Mariner serial # OB193908. I bought a Seloc manual but it dosen't cover the motor i have. I'm trying to set the timing. It has dots instead of numbered degrees. Would appreciate info on correct manual and explanation of dots?"
  2. #2
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,127
    Default "If you have the Seloc's m
    "If you have the Seloc's manual for "Mariners" then you got the one for the Yami built models - yours is a Merc/Mariner so you need the "Seloc's for 1&2 cylinder Mercs 1965-91".
    Anyhow, the two setting regarding the dots you need to know are the "idle timing in gear" which is 2 degrees ATDC (after top dead center).
    This is located at the first (tick) mark to the right of the SINGLE dot.
    Your max timing advance, at wide open throttle is at 25 degrees BTDC (before top dead center) which is bang on the 3 DOTS....."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  3. #3
    Default "Thank you for the reply, info
    "Thank you for the reply, info is very helpfull."
Similar Threads
  1. service manual 1980 120 hp
    By iwish in forum Mercruiser Sterndrive Forum
    Last Post: 08-18-2010, 09:23 PM
  2. service manual
    By redrider in forum Mercury Mariner Outboard Forum
    Last Post: 07-14-2010, 06:33 AM
  3. Mercury Mariner 8hp 2 cylinder 1989 Factory service Manual? Week Spark.
    By Ted Speedy in forum Mercury Mariner Outboard Forum
    Last Post: 04-25-2010, 12:55 AM
  4. Service Manual 1999 4.3
    By emptyhead123 in forum Mercruiser Sterndrive Forum
    Last Post: 03-31-2010, 07:03 PM
  5. Need Service Manual
    By starfishkiller in forum Archive 2002-2006
    Last Post: 01-26-2004, 07:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
