1996 225 hp 2stroke oil injection issue
bird203
Hard to start after shut down. Found the oil injection oil when shut down is flowing into the fuel system as seen at the engine glass bulb. Trying to restart only fouls the plugs.Fuel pump rebuilt last year. Releasing the pressure on the oil tank stops this problem but is a pain to get to the tank. IDEAS?
The pressure is realesed by th
The pressure is realesed by the same valve that created it. Trace the air line to the P/H stbd. side. Replace that valve.
"Replaced the valve today with
"Replaced the valve today with a new style which replaced the old valve. This one I was able to blow air thru both ways so it will bleed the air off the oil tank after shut down. The other I was unable to blow air. Tested and ran for some time, shut down, checked an hour later and no pressure remains. Many thanks."
"<[img]"http://www.marineengin
