" Dogman,
In complete
" Dogman,
In complete agreement with Joe, here's some more suggestions.
1. Have the seller leave the engine cold next time you go see it, and start it up yourself. Hard starting probably doesn't point to a major problem, but it's nice to know for sure before you get it home.
2. Check the electrical system in the boat, everything should be clean and neat. Look around the batteries and under the "dash" where the instruments around mounted etc.. The wire and terminals should be marine grade and well insulated. You should see very few splices and butt end connectors, if a bunch of wires are getting power or ground from a common lead, it should have been done with power posts/power bars. The batter
(ies) should be marine starting or starting/deep cycle. If the wiring is a mess plan on spending a minimum of $200 to do it right, good batteries are a minimum of $60 a piece.
3. Check the condition of any glass on the boat, look around the edges for small stress cracks; plexiglass, which is the cheap alternative to safety glass or lexan tends to get brittle over time and crack. Plan on spending about $200 to replace a set (2) of 2 X 2 windows correctly (with safety glass or lexan).
4. This part is something I hate doing, but it does give you a better idea of the hull condition. Wherever you have access to the bilge, it's usually in the stern under the engine well somewhere, lay down and take a look in there with a flashlight. Check the condition of whatever bilge pump / auto switch is in there and MOST IMPORTANTLY, poke around and check to see if the fiberglass is still solid in there. The bilge is going to be the first place where things will soften up. It will be dirty etc, but wipe it away and you should feel is clean solid fiberglass. If any fabric is seperating or you see any strange repairs/supports be sure you know what you are getting into. The fact that the floor is soft is good reason to be suspicious of other areas.
5. Transom and Hull; you said the hull was in good shape, but take a hard look for stress cracks. The floor in a fiberglass boat often provides a degree of support, when it rots out
that support is gone. The transom should be solid, if you bang on it, it should have a sharp sound, like a dry block of wood. If it makes more of a "thud" than a "knock" or feels a little soft, that's a sign that the transom is rotting - this is a pain in the @ss on a fiberglass boat to repair and most often means junking it. There should not be any strange supports on either side of the transom (ie large block of wood), backing plates for the bolts holding the engine on are acceptable and neccesary, but a 2 foot chunk of half inch aluminum is suspicious. A thin "pad" between the outboard and the transom is OK. If there are holes in the transom from engines past, they should be sealed with some type of epoxy filler, and should not be exposed.
6. Check the hull for a "hook" or "rocker"; often thinner low boats, like ski boats or bass boats with outboards, get bent from not being correctly supported on the trailor. The stern of the boat needs to be supported well to hold that 450 lb outboard. A hook is a dent just forward of the stern caused by a "bent" boat, and a rocker is the same as a hook, except for it is a bump just forward of the stern. By looking down the whole length of the bottom of the boat and sighting it up like a shotgun you can detect these defects. Bothe a hook and rocker lead to poor performance, such as excessive chine walking, or porpoising.
Oh, and be sure you know what you are getting into with that floor.. Repairs like that are tricky, I would recommend using a two part epoxy resin for bothe sides the new floor, it's easier to work with and lasts more or less forever, well worth the extra $40 a gallon (not polyester,"fiberglass",or vinylester - they don't stick as well and allow things to rot as you can see). In addition, you probably should also be replacing the foam floatation under the floor at the same time, it often soaks up water and becomes heavy and useless - I have used pink foam insulation and "great stuff" spray foam before, but they actually do make foam just for floatation replacement purposes.
Hope this helps,
Jon "
