Chrysler 331 hemi m45s 1955
331_hemi
Hi I need to get a complite ga
Hi I need to get a complite gasket set fore the MARINE engine m-45-s (the marine gasket parts)
wear can I get this?
regards Johan Karlsson Sweden.
Johan:
If this is a fresh w
Johan:
If this is a fresh water cooled engine (with an enclosed cooling system) then you can use regular automotive gaskets. They are far easier to find! Not sure where you would get marine gaskets for that motor.
Jeff
"Hi I do have the atomotive ga
"Hi I do have the atomotive gasket allredy it the specifk marine gasket I need tex, oilpann gasket
redards Johan."
Sorry. Do not know where to g
Sorry. Do not know where to get parts for such an old engine.
Try these guys:
slantsix.com
Jeff
"Johan, As Jeff suggested, the
"Johan, As Jeff suggested, the high grade automotive head gaskets will work if, and only IF, your engine is Closed System cooled.
You will eventually have trouble with the automotive set if Sea Water or Raw Water cooled. It will simply be a matter of time before they start to fail."
Re: Hi I need to get a complite ga
olsongaskets can hook u up...complet set with copper hd gskts....reverse gear gskts and everything......ggole it therer in wa
