150 HPDI oil tank leak on engine
larrywit
this motor leaks from the rese
this motor leaks from the reservoir under the cowling when it is tilted out of the water it is coming out from the cap on top of the tank..is there a new tank capor fix that will stop the problem..boat is in water all the time tilting is a must..
thanks larrywit
i put the zip ties on 2/1 wedn
i put the zip ties on 2/1 wednesday..i did notice that the rubber caps are starting to crack/split in some spots.. i told the owner new ones may be needed down the road..it has been too rough to take the boat offshore 3 to 5s every day..any idea as to cost of new caps with sensor..
larrywit
