Results 1 to 9 of 9
  1. #1
    Default "HI, I just got a super de
    "HI,
    I just got a super deal on a 29 ft lakescraft pontoon, now the bad news. It has a stringer outdrive that is bad, I would like to change everything over to Alpha 1. Did anybody do this already? Or does anybody have some helpful tips?
    Thanks in Advance"
  2. #2
    Join Date
    Mar 2008
    Location
    Manalapan, nj, usa
    Posts
    3,727
    Default "you will have to close the dr
    "you will have to close the drive hole and then recut a new hole, that is if you want to keep the old motor.
    Then you will have to get everything new from the flywheel back.
    Best way is to have a donor boat with a bad hull that has the drive you want."
  3. #3
    Default "Bill,as chiefalen points out,
    "Bill,as chiefalen points out, theres no "easy" way of doing this. No one makes a transom adapter plate that will close down that big hole you'll have left when you pull the stringer set up.You will need to do some wood core and glass work to fill it in,then cut out the new hole for the merc style plate.Since this area will bear alot of weight,unless you are an accomplished glass-man,leave it to a pro.I've seen some DIY jobs that have gone ugly after only a few trips out.Good luck."
  4. #4
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    8,605
    Default "Yes..... agreed! This would b
    "Yes..... agreed! This would be a good thing to do if the boat is worth salvaging!
    This is no doubt an older boat since it had the OMC Stringer drive. Have you considered an AQ series Volvo Penta drive? Probably less expensive and it is a better drive, IMO!
    Keep in mind that a "Stringer" drive did not require a structural transom.
    Many of these were one layer only of plywood core material.
    This is not necessarily a deal breaker, so long as you realize that a greater "build-up" of core material is necessary for a transom mounted stern drive..... (two layers vs only one).
    I'd say that a project like this is very doable!
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs!
    I would prefer email .... jenery (at) aol.com
  5. #5
    Default "Thanks for the info, the boa
    "Thanks for the info, the boat is a 29 ft beachcomber pontoon. The transit is alu, so it looks like a welding project. I just got the motor out and the oil pan has holes rusted in it. HAHA.
    I planned on using mercruiser outdrive, not sure if I put in a 4.3 V6 or a 3.0 4cly.
    I work at a marine and have plenty of parts laying around that I can use. When I get the hole closed is the a certain height I need to watch out for when I make the new holes? Or do you thing the motor mounts will be adjustable if there off some?"
  6. #6
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    8,605
    Default Yes.... The "X" dimens
    Yes.... The "X" dimension will be important!
    Mercruiser will offer this in one of the factory installation manuals.
    Portland, Oregon
    Please... no PMs!
  7. #7
    Join Date
    Nov 2006
    Location
    , Ontario, Canada
    Posts
    292
    Default "What motor had the rusted out
    "What motor had the rusted out oilpan? Is it an old Buick V6, by chance?????"
  8. #8
    Default No it was a inline 4 cly
  9. #9
    Join Date
    Mar 2008
    Location
    Manalapan, nj, usa
    Posts
    3,727
    Default "The motor runs? You really ne
    "The motor runs? You really need more power with that pontoon? More power more weight? Will the back of the boat handle the weight? Whats recommended for that, boat power wise."
Similar Threads
  1. Swap Alpha I/MR with Alpha GenII ?
    By 30 Commander in forum Mercruiser Sterndrive Forum
    Last Post: 12-23-2010, 04:09 PM
  2. 1991 alpha gen 2 transom assembly to a 1986 alpha
    By lime4x4 in forum Mercruiser Sterndrive Archive
    Last Post: 08-19-2009, 10:41 PM
  3. Pointless ignition conversion on 800 stringer 185 gm 305
    By thomtrox in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-22-2008, 02:29 PM
  4. Can you replace a alpha 1 w a Alpha Gen 2 Drive
    By mikem40 in forum Mercruiser Sterndrive Archive
    Last Post: 09-30-2007, 10:41 PM
  5. Pre alpha outdrive compatability with alpha 1
    By daveolejnik in forum Mercruiser Sterndrive Archive
    Last Post: 04-18-2007, 11:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
