"It would help anyone who is d
"It would help anyone who is doing this procedure for the first time, to understand the simple geometry between the
engine "centerline", the
Gimbal Bearing centerline, and most importantly..... the
hinge point that occurs at the two rear engine mounts as the engine front moves UP/DOWN from hull flex, mount sag, etc!
You should be able to see how the FWD engine mount "height adjustment" affects this!
(It's this hinge point that we are correcting!)
By aligning these, we hope to achieve as close to true center line as possible!
The reading of the grease line is rather crude..... but it does work... and has for years!
Here is a schematic of the gimbal bell, gimbal bearing and drive coupler. It shows an alignment tool in position.
Unfortunately, this image does not show the rear engine mounts! To best explain this, a good image that would include the rear mounts is needed! (see next image)
This shows the rear engine mounts on the flywheel cover only. There will be two accommodating mounts on the inner transom plate.
When the raising or lowering of the front of engine, this becomes a hinge point (so to speak)..... and this is what we are correcting.
Engine front too low.... and the male shaft splines ride high within the coupler.
Engine front too high.... and the male shaft splines ride low within the coupler.
If someone were to have a better image to post, that would be great!
