B75 anode
edevon
My early B75 does not appear t
My early B75 does not appear to be fitted with a sacrificial anode. Is it recommended to obtain and retro fit one?
Check under the horizontal fin
Check under the horizontal fin just above the prop..
The older B75 had a small button sized anode that was recessed under the plate above the prop. The newer ones had a larger rectangular shaped one mounted on the port side on the top of the horizontal plate.
It appears that the button has limited availability for about $15.00
