"Bob, Oh no..... you are not s
"Bob, Oh no..... you are not stepping on my toes at all. I'm a big boy and I appreciate that!
Pound per pound, the BBC 454 will outperform the BBF 460 unless extensive cylinder head work is done. Add to this the availability of exhaust manifolds and drive couplers, and you have an expensive scenario. IMO.
I still say that the KC drive is one to steer clear of, regardless of a 454 or 460.
And just to be clear...... an additional advantage of the swap to Volvo is the future adaptation of the Duo Prop lower unit.
I can't say enough good about the DP!
The performance of a 454/460 w/ a single prop drive can easily be accomplished with a SBC 383 and a Volvo Penta Duo Prop drive..... and you've shaved almost 240 pounds from the stern!
Add to this:
**No ESA ever again!
**Cone Clutch gear engagement!
**No parts availability issues!
It would appear to be a win win, IMO!
So Matt, whether BBC 454 or BBF 460, ya still have a KC drive!
That is an issue along with BBF parts!
And to answer your question on OMC parts..... the parts for the Cobra are still readily available as "after-market"..... it's the King that is the problem.
Again, I'm not suggesting RUN, but I am suggesting that you consider all of this!
And consider the cost of an upgrade should you have issues!
I frequent a forum where this very topic has cropped up many many times.
And constant ESA issues that the average Joe just can't figure out!
Stuart Hastings comes to mind!
Mat, in 1993 Volvo Penta owned and operated the company. The "Cobra" name did appear on the first few models, if memory serves me.
The KC was not continued.
Morten, while the post '92 Cobra did show the influence of V/P..... the drive parts do not interchange to my knowledge! (V/P lower will not bolt on to a Cobra upper, for example)
And don't forget the successor to the 290.... the SP C and DP C, etc.
These are still part of the AQ series family, and the best ones yet, IMO.
Again, Mat..... if you can pick up one of these for change on the dollar, and if budget allows for future issues, I see no foul!
Just don't throw money at the OMC drives. Go to the Volvo Penta and end the issues.
You do not necessarily need to purchase new.... there are lots of good used V/P drives from damaged boats out there.
Oh, and my best advice yet;
Boats are never investments, Mat...... they are always expenses. We just use it up in the form of enjoyment.
I am very upside down in my restored 28 foot SDN F/B boat (new engines/new DP drives, etc).... and I do not mind at all! It serves me well, it will run with the best of them.... and I'll use it up!
