eric_hawaii
"Aloha everyone,
I am having
"Aloha everyone,
I am having some issues with my 2006 Honda BF90's. I have read through alot of the previous post but cant seem to find something similar to my situation. Currently i have approx.1500 hours on the pair and my port engine is giving me problems. I use the boat daily for channel crossing's here in Hawaii so the motors get quite a bit of use. I do all the scheduled maintenance and even beyond. So far the motors have been very reliable with the exception of carb jobs which i have had done three times between the two motors. This motors starter isnt working properly and you can here it working but it isnt engaging. In addition to that the trim started acting up and when you hit the trim button you get nothing for a few seconds and then it Also, the motor is running really rough at idle, shaking really bad, and stalling initially until it warms up. At high speed it seems to have some power loss but it runs smoother then idle. In the past we have had the low speed jet issue resolved and i understand that whole concept about smoothing out at WOT if your lows are clogged but it seems to be something more. In addition to all of this both motors have been creating black soot after a days use. I have to wipe it off around the exhaust port after every use. Now, my questions are:
1. Any clues on what the issue could be?
2. Is it worth putting more money into these motors with the high amount of hours?
3. How long do these engines typically last?
4. Could the carbs be clogged or out of sync again? this would be the fourth overhaul.
Any advice is much appreciated. thank you very much and happy new year!"
I am having
"Aloha everyone,
