"Hello:
We are in the proce
"Hello:
We are in the process of surveying a Tollycraft with twin Crusader 454 CID 350 HPs.
When the survey started, it was determined that the lower 90 degree elbow on the outer side of port engine was disconnected. This is the part of the system which leads directly to the waterlift muffler and the exhaust thruhull.
The surveyor was able to jack up the elbow so that the vertical section of hose could be reclamped to the upper 90 degree elbow. There was no hanger so the hose and elbow were supported only by the hose clamps. This seems like a lot of weight especially since the inner side of the exhaust system was also attached with a t fitting.
At the dock, the engine started fine. However, on the sea trial, the lower elbow and hose popped off the upper elbow again.
Any ideas about what may be causing this? Is there suppose to be a hanger or could it be a restriction in the exhaust system?
Thanks."
We are in the proce
"Hello:
Thanks."
