N
Neil Cunningham
Guest
" I have a 25 HP Johnson with
" I have a 25 HP Johnson with a steering system that is frozen.
I disconnected the nut at the extreme end of the cable that connects to the link arm, then unscrewed the large nuts on both sides of the tilt tube.
At this point, steering wheel moves freely. The piston on the helm side also moves freely in and out of the tilt tube.
However, the piston coming out of the tilt tube (side that connects to the link arm) is frozen tight.
I have not removed the entire cable from the tilt tube, but am assuming that it is broken inside.
When I push the helm to a fully extended position, I feel and hear a distinct click. When I reverse the helm, I feel and hear a similar click.
Any thoughts on what I should do will be greatly appreciated.
Neil C. "
Neil C. "
