T
T Vickers
Guest
" Hi-
I recently purchased
" Hi-
I recently purchased a 1972 Larson with a 100 HP Johnson. I decided to change the lower gear oil before taking it out. I used "type C" gear oil for engines with electronic shift. After changing the oil I fired up the engine. It ran fine for 30-60 seconds, then stopped and won't start again. I've checked the fuel line and there seems to be plenty of gas getting to the motor. Is there any way that changing the gear oil can effect the way the engine runs in neutral? Any other ideas?? Thanks for the Help!! "
" Hi-
