Results 1 to 2 of 2
    Dec 2007
    falmouth, st pauls, antigua
    51
    Default "Ok the engine end of the gear
    "Ok the engine end of the gear cable does not move.
    I cant get the side mounted remote off to take a look. The rear of it is behind a panel and can not be seen. There are four screws on a panel aft of the control rotor which come out easy but thats it. Do you pull off the handle? what?. Do the cables break ever? I am in Antigua and we have no professional fixers or agents so I am fairly desperate, but fairly handy. Tips would be much appreciated."
    Feb 2009
    perth, wa, Australia
    956
    Default "Yes the handle needs to be re
    "Yes the handle needs to be removed. Yes cables do break, levers inside the unit also wear and or break...you need to remove it and pull it apart to access the problem"
  1. 1998 Johnson 200 hp Ocean Pro
    By jshane37 in forum Johnson Evinrude Outboard Forum
    Last Post: 04-21-2010, 10:26 PM
  2. No gear shift 1998 200 hp evinrude
    By interd0g in forum Johnson Evinrude Outboard Archive
    Last Post: 12-17-2009, 11:01 AM
  3. 1998 200 ocean runner
    By bholterman in forum Johnson Evinrude Outboard Archive
    Last Post: 08-19-2009, 12:58 PM
  4. 1998 Evinrude Ocean Pro
    By jddar in forum Johnson Evinrude Outboard Archive
    Last Post: 05-12-2007, 08:53 PM
  5. Evinrude Ocean Pro 200 1998
    By eckland in forum Johnson Evinrude Outboard Archive
    Last Post: 05-03-2007, 07:32 AM
