Results 1 to 2 of 2
    Dec 2007
    falmouth, st pauls, antigua
    51
    Default "When you push the control, th
    "When you push the control, the gear shift push rod at the engine end does not move. The shift was very stiff prior.
    i cant get the single lever control apart to investigate, although i have removed the 4 visible screws . It is a side mounted concealed cable type an a Seaswirl Striper. Any words of wisdom?
    There are no parts here in Antigua so i will need to specify any parts right first time and import them. Thanks in advance for any tips"
    Sep 2006
    SF BAY AREA, CALI, USA
    8,649
    Default sounds like bad shifter to me
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
  1. Oceanpro shift interrupt switch 1998
    By interd0g in forum Johnson Evinrude Outboard Forum
    Last Post: 08-28-2010, 12:28 PM
  2. 1998 150 hp Starts in gear.
    By DBall54 in forum Johnson Evinrude Outboard Forum
    Last Post: 05-02-2010, 07:47 AM
  3. No gear shift 1998 Ocean Pro
    By interd0g in forum Johnson Evinrude Outboard Archive
    Last Post: 12-17-2009, 09:51 PM
  4. 1998 150hp evinrude motor slips out of gear
    By Mario Valenzuela in forum Johnson Evinrude Outboard Archive
    Last Post: 03-27-2004, 02:14 PM
  5. 1998 115 Evinrude Wonbt Shift into forward
    By Tony Blanton in forum Johnson Evinrude Outboard Archive
    Last Post: 03-08-2004, 07:51 AM
