Results 1 to 5 of 5
Thread: 140 Johnson
  1. #1
    Default I have a 1977 140 johnson that
    I have a 1977 140 johnson that rolls over real slowly even with a new battery. Could the starter be bad?
    thanks for any help
  2. #2
    Join Date
    Oct 2009
    Location
    Olando, FL, USA
    Posts
    41
    Default Yes it could. If you can turn
    Yes it could.
    If you can turn the motor flywheel by hand.
    Then it is most likely a bad starter.
  3. #3
    Default Thanks. I can turn the flywhee
    Thanks. I can turn the flywheel by hand so I'll try a new starter
  4. #4
    Join Date
    May 2009
    Location
    Marine Engine
    Posts
    564
    Default do you know if it is a prestol
    do you know if it is a prestolite or a bosh ?
    starter
  5. #5
    Default No I do not as I have not pull
    No I do not as I have not pulled the old one. Is there a difference and if so how can I tell. I thought I would find a number on the old one and order from that. Is that correct?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
