Results 1 to 4 of 4
  1. #1
    Join Date
    Dec 2009
    Location
    Tenerife Spain
    Posts
    2
    Default "My battery is absolutely dead
    "My battery is absolutely dead but I can not read properly the amps on it for a new one for my Evinrude 70 no electric trim (S/N 4447417). Can you tell me, please, how many amps I need for a new 12 V. battery? Maybe in the 60-80 A range?
    Thanks in advance"
  2. #2
    Join Date
    Nov 2005
    Location
    lockhart, texas, US
    Posts
    5,812
    Default 500 cca marine
    500 cca marine
  3. #3
    Join Date
    May 2008
    Location
    Kent, the garden of England, UK
    Posts
    1,201
    Default JWBMarine's figure refers
    JWBMarine's figure refers to the Cold cranking amps (CCA) your 60-80 guess is the battery capacity in ampere-hours (Ah)
    The CCA figure is the one that is more relevant to a starting battery but a starter battery of around 70Ah should give you the 500CCA he recommends.
  4. #4
    Join Date
    Dec 2009
    Location
    Tenerife Spain
    Posts
    2
    Default "Thank you, guys I live in Ca
    "Thank you, guys
    I live in Canary Islands, subtropical zone, 28N 14 W. Wel, Im going to pick a 76 Ah and 560 CC battery for 70 Euros. I just removed the old battery today and when you balance it, sounds like a river running inside. I think it can have two or more cells broken.
    Thanks again.
    PD: This page and forum has been added to "My favourites""
Similar Threads
  1. Battery replacement
    By jaredandrew206 in forum Boat Electrical Systems
    Last Post: 03-13-2010, 12:13 PM
  2. 1997 Johnson 70Hp battery
    By saracen in forum Johnson Evinrude Outboard Archive
    Last Post: 03-17-2008, 08:42 AM
  3. Replacement carb for 1997 57 Merc
    By Need Help in forum Mercruiser Sterndrive Archive
    Last Post: 07-23-2006, 11:13 PM
  4. Impeller replacement 1997 40HP Mariner 4 cycl
    By Ed Dorsch in forum Johnson Evinrude Outboard Archive
    Last Post: 04-17-2003, 08:53 PM
  5. 1997 Johnson 115 battery charging problem
    By fatboy in forum Outboard motors archive 2000-2004
    Last Post: 12-13-2002, 03:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
