Results 1 to 2 of 2
  1. #1
    Join Date
    Nov 2009
    Location
    hanceville , al, usa
    Posts
    49
    Default "I have a 70 hp evinrude 1977
    "I have a 70 hp evinrude 1977 and a 90 hp force 1995, both of them are doing same. they start slipping after you go past half throttle, the evinrude just did it today, I have been told it is probally the prop spun out, but i havent hit anything on the evinrude to spin it. last time i went out it was fine, but i changed the oil in the lower unit can wrong oil do this? its not clicking when they slip either. I read something in a manuel about the exhaust diffuer being bad could cause bubbles around prop but just thought i would see if someone could help."
  2. #2
    Join Date
    May 2009
    Location
    Posts
    371
    Default "Props slip from old age too.
    "Props slip from old age too. Take a look at the innards, after you pull the nut and washer. You will see an inner portion that slips over the propshaft, the rubber hub, and the inner prop flange. Put a mark on the inner portion, and the outer portion, so that they line up. Run the boat until the prop slips. Then see if they still line up. If not, hub is slipping. Most propeller stations will rehub very reasonably."
Similar Threads
  1. 1979 6hp Evinrude shift lever slipping
    By riverbow in forum Johnson Evinrude Outboard Forum
    Last Post: 08-08-2010, 06:38 PM
  2. 1972 Evinrude slipping out of gear
    By lois in forum Johnson Evinrude Outboard Archive
    Last Post: 07-09-2007, 02:52 PM
  3. Evinrude 25hp slipping
    By bobby in forum Johnson Evinrude Outboard Archive
    Last Post: 11-17-2003, 08:56 AM
  4. 1996 Evinrude Ocean Pro prop feels like itbs slipping
    By Bob in FL. in forum Johnson Evinrude Outboard Archive
    Last Post: 11-08-2003, 12:02 PM
  5. 1975 Evinrude 115 hp Help its slipping Joe
    By Brett White in forum Johnson Evinrude Outboard Forum
    Last Post: 10-24-2002, 10:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
