I am in negotiation to purchas
I am in negotiation to purchase a BW Dauntless (16') with 1999 Yamaha 100 4 stroke. The survey indicated the engine has some corrosion on the main yoke attachment to power head.. This is the part the sterring arm attaches to. Evidently Yamaha used cast part with low grade SS bolts in early versions of this engine.. If crrosion is bad the whole motor has to be disassembled to replace bad part-- this is part one of engine assembly..
I would appreciate the forums experience with this engine.. As it is a 10 yr old engine - i'm not expecting much from it.. I would hope this corrosion issue is more cosmetic vs immenent failure.
Thanks for any input.
Drew
Drew
