"Hey Chief, been a while...
To the OP, I'm no expert by any means, but I had the same problem when I first got mine running. After JBWelding the plugs, the problem was better, but not solved. I doscovered that the brand new float (as well as the old one that ended up being good) was not holding the 5-6psi the pump was putting out. Thus, it would flood very easy and would dribble slightly when turned off. After getting tired of everyone telling my newly rebuilt carb, needed to be rebuilt, I bought a regulator at checker. I set it for 3psi and problem solved.
I used my compressor and put 5 psi to the carb inlet. It never would stop unless I had the float set almost all the way down.
If you test this way, make sure your bowl is full, and there is fuel in the line so your pushing fuel to the carb as it would normally be operating."
