Results 1 to 5 of 5
  1. #1
    Join Date
    May 2009
    Location
    Posts
    371
    Default "Boat on a lift? Need to do s
    "Boat on a lift? Need to do some work on it? Can't reach anything from the dock? I went through this hassle. Had boat lift guy out spouting about this type of platform, and that, $1000 for this, $900 for that. I came up with the best solution. Pair of 8' 2x4's, overlapped a foot or so, sandwiched using deck screws, gives me a working length of about 12'. Two 8 footers with a 4' piece across the bottom for a base to sit on the bottom, toward the middle or end. Sheet of scrap plywood for the decking. Mine goes perpendicular to the seawall and dock, and the 2x4's slide right under the seawall cap. Build time, a couple of hours. Total cost less than $30. When you are done, trash or re-use the lumber. Mine has been up for months, and the Home Owner demons haven't even complained yet!"
  2. #2
    Join Date
    Nov 2005
    Location
    Posts
    233
    Default a picture is worth a 1000 word
    a picture is worth a 1000 words!
  3. #3
    Join Date
    May 2009
    Location
    Posts
    371
    Default Never had any luck posting pic
    Never had any luck posting pictures to this site. Any idea how?
  4. #4
    Join Date
    Nov 2005
    Location
    Posts
    233
    Default I think I hosted mine on photo
    I think I hosted mine on photobucket and linked the image to here.
  5. #5
    Join Date
    May 2009
    Location
    Posts
    371
    Default "Tried to post a picture. As
    "Tried to post a picture. As usual, I get an error message saying the file is too large. I used the lowest resolution picture imaginable, still the error message. Same as always."
Similar Threads
  1. Swim Platform Trolling Motor Brackets
    By ajaymuch in forum Mercruiser Sterndrive Forum
    Last Post: 09-17-2016, 02:10 PM
  2. Will it work
    By tomc203 in forum Mercruiser Sterndrive Archive
    Last Post: 05-17-2009, 02:28 PM
  3. Swim platform
    By letsrock in forum Miscellaneous marine engine topics
    Last Post: 04-14-2008, 05:49 PM
  4. Will it work
    By W. Sadler in forum OMC Sterndrive and Inboard Archive
    Last Post: 11-01-2006, 08:15 AM
  5. I need some help please Will this work
    By pritchettk in forum Mercury Mariner Outboard Archive
    Last Post: 06-25-2006, 05:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
