Results 1 to 2 of 2
Thread: Air jets
  1. #1
    Join Date
    Aug 2008
    Location
    Posts
    433
    Default "quick question: when chang
    "quick question:
    when changing the air jets on a motor, does the fuel feed in to the carb changes too?
    ie. if one increases/decreases on size of air jets that changes the quantity of fuel being metered or fuel remains constant changing only air amount that the jet lets flow in to the carb???"
  2. #2
    Join Date
    Feb 2009
    Location
    perth, wa, Australia
    Posts
    956
    Default Air jets bleed air into the fu
    Air jets bleed air into the fuel circuit...so the engine is drawing less fuel with bigger air jets.
Similar Threads
  1. Jets and rpm ranges
    By nicknack2 in forum Johnson Evinrude Outboard Forum
    Last Post: 02-19-2010, 11:20 PM
  2. Carb jets
    By sanford in forum Johnson Evinrude Outboard Archive
    Last Post: 05-26-2008, 09:58 AM
  3. USED JOHNSONEVINRUDE JETS
    By big_jack in forum Johnson Evinrude Outboard Archive
    Last Post: 07-18-2007, 10:01 PM
  4. Carburettor jets
    By nomes in forum Yamaha Outboard Archive
    Last Post: 04-08-2007, 05:19 PM
  5. NissanTohatsu 35 jets
    By randyjaco in forum Nissan Tohatsu Outboard Archive
    Last Post: 02-24-2006, 05:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
