Results 1 to 11 of 11
  1. #1
    Join Date
    Aug 2006
    Location
    , NorthCentral Alabama,
    Posts
    207
    Default "My cylinders are stuck. Wont
    "My cylinders are stuck. Wont go up or down.
    Anybody have a hint as to the correct way to get this stuff all loosend up?Motor stuck in upright position
  2. #2
    Join Date
    May 2009
    Location
    Marine Engine
    Posts
    564
    Default try to open the by pass screw
    try to open the by pass screw on the right side and see if it moves that way??
  3. #3
    Join Date
    Jul 2009
    Location
    Duluth, MN, USA
    Posts
    338
    Default "I'll bet your fluid is co
    "I'll bet your fluid is contaminated.....looks like boat is always stored outside. I think the entire trim tilt needs to be drained then refilled/flushed with ATF then if it works without dismantling, drain out ATF then use proper tilt/trim fluid. I would expect it was stored with contaminated fluid and will need dismantle and possibly some kits. Go ahead and try the drain and flush first.....its a good idea anyway. These units get infected usually through the motor seals as the lower motor shaft/bushing wears and wrecks the seal allowing any moisture that has collected in the upper motor housing to enter the reservoir."
  4. #4
    Join Date
    Aug 2006
    Location
    Posts
    207
    Default "Yes, the boat's been outs
    "Yes, the boat's been outside all its life. It hasn't been used since 06.
    Would 30wt motor oil be the right stuff? That's what my Mercruiser used."
  5. #5
    Join Date
    Feb 2004
    Location
    Posts
    340
    Default Try what Cliff said in his pos
    Try what Cliff said in his post...You can now lift the motor up and it will go back down by itself..Do you hear the relays clicking when you try to move the motor..?
  6. #6
    Join Date
    Feb 2004
    Location
    Posts
    340
    Default I just noticed that your setup
    I just noticed that your setup had the EXTERNAL tilt and trim system....the old style that was stoped being used in the early seventys...What is the model No. of your motor..?
  7. #7
    Join Date
    Aug 2006
    Location
    Posts
    207
    Default Whoa up! Its cold here now.
    Whoa up!
    Its cold here now. I'll get it out in the Daylight and try some of your magic and get those numbers too.
  8. #8
    Join Date
    Jul 2009
    Location
    Duluth, MN, USA
    Posts
    338
    Default I've worked on this T/T de
    I've worked on this T/T design up to mid 80's. If the fluid gets contaminated the little check balls will stick inside the pump housing. Even if the electric tilt motor runs......nothing will happen. I would not recommend 30W oil unless its hydraulic oil. That viscosity may be a bit heavy for temps below 50 degrees F.
  9. #9
    Join Date
    Jun 2006
    Location
    JASPER, IN., USA
    Posts
    75
    Default "Timothy: Isn`t the right cyli
    "Timothy: Isn`t the right cylinder the tilt cylinder that lifts the motor,,,,and the left one is the trim cylinder on those old units?"
  10. #10
    Join Date
    Aug 2006
    Location
    Posts
    207
    Default "I finally got the Numbers. Th
    "I finally got the Numbers. They are difficult to get to if you cannot move the motor.
    85 ETL 76D
    J4566859
    There are two large cylinders, one on each side, and two smaller cylinder in the center, one on each side.
    rightside pump n' cylinder"">
    left side
  11. #11
    Join Date
    Jul 2009
    Location
    Duluth, MN, USA
    Posts
    338
    Default "Yes that is right, Jack. The
    "Yes that is right, Jack. The small inboard cyls help support the motor weight and act as dampeners. This looks pretty bad as if things have been leaking. I might not be too hopeful for a simple fix. May need overhauling/kits. Nothing is available for the pump itself however. You have to look for used pumps. Housings are available but rarely needed anyway."
Similar Threads
  1. trim tilt doesnt trim tilt on my 1987 70 hp johnson outboard
    By OBG in forum Johnson Evinrude Outboard Forum
    Last Post: 10-15-2016, 02:05 AM
  2. 1980 85 hp javlin johnson outboard
    By violette in forum Johnson Evinrude Outboard Archive
    Last Post: 05-20-2008, 10:28 AM
  3. b98 Johnson 70 HP trim tilt
    By donq in forum Johnson Evinrude Outboard Archive
    Last Post: 04-18-2008, 09:42 AM
  4. 95 Johnson no tilt trim
    By glc in forum Johnson Evinrude Outboard Archive
    Last Post: 02-02-2008, 07:49 AM
  5. 85 hp johnson javlin
    By [email protected] in forum Outboard motors archive 2000-2004
    Last Post: 04-11-2002, 12:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
