Results 1 to 4 of 4
    Oct 2009
    Kalamazoo, MI, USA
    25
    Default "Hello again...the project con
    "Hello again...the project continues. Does this motor have a fuel filter? I have a manual and can't find one. If it has one, where do I look? Thanks!"
    Jul 2009
    Duluth, MN, USA
    338
    Default "There is a very fine half dol
    "There is a very fine half dollar size screen in the bottom of the fuel tank, it can be accessed by removing top of the tank. Then you can completely clean out tank. I use hot soapy water, then wipe dry or use wet vac. Tank cannot pass dirt past this screen."
    Oct 2009
    Kalamazoo, MI, USA
    25
    Default Thanks very much for your resp
    Thanks very much for your response and info...
    Jul 2009
    Duluth, MN, USA
    338
    Default "Your very welcome. Also I hav
    "Your very welcome. Also I have added small "in-line" filters just before the carb on some motors that I know will have unknown or different tanks connected to them. In the old days we had a fleet of the "double line" outboards at our resort and it was cheap insurance to protect the carbs from contaminants. Guests can do some funny things when they are out in the bush. Even some dirt can get on the motor fitting and if its not cleaned off before the line is attached, of course it can get into the carb."
  1. Another 1954 Fleetwin question re points condenser
    By gnshowzaolcom in forum Johnson Evinrude Outboard Archive
    Last Post: 12-10-2009, 06:16 PM
  2. Sparkplug wires for 1954 75 hp Fleetwin
    Last Post: 11-24-2009, 10:05 AM
  3. 1954 Evinrude 75 Fleetwin is this normal
    By piperjak in forum Johnson Evinrude Outboard Archive
    Last Post: 04-25-2009, 01:19 PM
  4. 1954 fleetwin 75
    By stewpid in forum Johnson Evinrude Outboard Archive
    Last Post: 03-26-2009, 03:32 PM
  5. Evinrude 3hp 1954 clogged fuel filter screw in bottom tank
    By john D Phillips in forum Johnson Evinrude Outboard Archive
    Last Post: 03-31-2007, 01:22 PM
