Results 1 to 4 of 4
    Nov 2009
    hayden, alabama, usa
    18
    Default was looking at my boat with a
    was looking at my boat with a friend and he said the prop wasn't down in the water far enough. the boat measures 16" from top to bottom and the motor is a 7.5 evinrude 83 model e8r cta. this is supposed to be a short shaft. will it work? thanks for any info. ted
    May 2008
    Kent, the garden of England, UK
    1,212
    Default "It will be OK. A long shaft
    "It will be OK. A long shaft would be too long.
    From the performance point of view the cavitation plate should be about level with the bottom of the transom but it is important that the water pump is submerged.
    It depends upon the type of boat you have and the hull shape. Small sail boat owners usually fit a longshaft engine to put the prop deeper in the water and the sail versions of Evinrudes and Johnsons are specially designed with that in mind
    A useful link here http://www.smalloutboards.com/shaft.htm
    BTW OMC outboards have "standard" shafts, other makes call them "short" shafts!"
    Feb 2009
    perth, wa, Australia
    956
    Default The cavitation plate should be
    The cavitation plate should be appprox 3/8" below the hull with a std type prop...the other influencing factor is if the hull has a keel that extends to the rear of the hull if it did the cav plate would be set level with the bottom of the keel
    Nov 2009
    18
    Default thanks for the info. i should
    thanks for the info. i should have told you that it is a 14x4 flatbottom. the previous boat it was on was a 14x2.5 with 12" fron top to bottom. it weights about half as much as the boat the motor is on now. ted
  1. long shaft to short shaft conversion 1984 25hp
    By Tward005 in forum Johnson Evinrude Outboard Forum
    Last Post: 07-07-2018, 01:16 PM
  2. late 70's or early 80's merc 50hp long shaft to short shaft
    By mike3079 in forum Mercury Mariner Outboard Forum
    Last Post: 05-23-2010, 07:40 PM
  3. Mounting long shaft motor on short shaft boat
    By kpangler in forum Mercury Mariner Outboard Archive
    Last Post: 01-31-2007, 07:58 PM
  4. 35hp Nissan 2stroke convert long shaft to short shaft
    By Dave Honey in forum Nissan Tohatsu Outboard Archive
    Last Post: 10-07-2006, 01:39 AM
  5. Any Advise on switching a Long Shaft to Short Shaft 25hp Johnson
    By garry in forum Johnson Evinrude Outboard Archive
    Last Post: 01-12-2004, 05:50 PM
