Results 1 to 6 of 6
  1. #1
    Default How much oil is normal coming
    How much oil is normal coming out of the prop area pls/adv
  2. #2
    Default "It is normal to have oil come
    "It is normal to have oil come out of the exhaust in the center of the prop on a 2 stroke, especially if you idled for a while before shutting it down. It is NOT normal for oil to come out of the gap between the prop and the gearbox; this indicates the failure of one or more seals in the gearcase.
    It is a good idea to post the year and hp of the motor when asking a question here."
  3. #3
    Join Date
    Feb 2009
    Location
    perth, wa, Australia
    Posts
    956
    Default The oil in your gearcase shoul
    The oil in your gearcase should be honey coloured (if its changed regulary) and exhaust residue from unburnt fuel will be black
  4. #4
    Default "Here is a pic of the area tha
    "Here is a pic of the area that the oil is coming out from it is a 1992 48 SPL Johnson 2 stroke thanks for the posts. This boat last ran in 2004 so is there a chance of build up. The color of oil was gray pls/adv
  5. #5
    Join Date
    May 2008
    Location
    Kent, the garden of England, UK
    Posts
    1,217
    Default "Almost certainly partly burnt
    "Almost certainly partly burnt oil from the fuel.
    Any doubts check the gear oil after it has run for a while.. you'll check or change it before you run it anyway won't you.
    Read THIS and THIS"
  6. #6
    Join Date
    Feb 2009
    Location
    Posts
    956
    Default Unburnt fuel washing carbon fr
    Unburnt fuel washing carbon from the exhaust tube to be sure undo the drain bung and check the colour of the gearcase oil.
Similar Threads
  1. A little diesel coming out the exhaust
    By lapaz000 in forum Detroit Diesel
    Last Post: 09-14-2009, 10:48 AM
  2. Oil Water mix coming from exhaust
    By Hugh Severs in forum Johnson Evinrude Outboard Archive
    Last Post: 10-04-2008, 11:33 PM
  3. Oil coming out of exhaust
    By RPerkins in forum Crusader Marine Archive
    Last Post: 11-05-2007, 05:57 PM
  4. Exhaust coming from prop
    By spectrumdominator in forum Mercury Mariner Outboard Archive
    Last Post: 03-02-2006, 11:36 PM
  5. Oil coming out exhaust port
    By ray in forum Outboard motors archive 2000-2004
    Last Post: 05-09-2002, 01:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
