Results 1 to 2 of 2
  1. #1
    Join Date
    Nov 2009
    Location
    hanceville , al, usa
    Posts
    49
    Default "what is the difference in hyp
    "what is the difference in hypoid oil and regular premium oil, does it have to say hypoid for it to be hypoid. Also I have 70 hp evinrude 1977 and was wandering what kind of oil I should use in lower unit on it."
  2. #2
    Join Date
    May 2008
    Location
    Kent, the garden of England, UK
    Posts
    1,200
    Default My understnding is as follows
    Outboard gears are not actually the type of spiral bevel gears that are known as "hypoid" That type of gear is subject to some sliding of the gear teeth faces so the oils used contain Extreme pressure (EP) additives. A Hypoid or EP type of oil is not therefore really necessary.
    I guess that in 1956 there were no oils specially formulated for outboards and that what were readily available were the EP oils for hypoid gears in vehicle rear axles.
    You should therefore be using an outboard gear oil probably SAE 85 or 90 viscosity which will contain corrosion inhibitors to counteract the effects of small amounts of water ingress (or so they tell us!)
    Electric shift outboards require a lower viscosity oil known as "type C"
    I confess personally to using an automotive EP90 oil in a small outboard.
Similar Threads
  1. 1991 johnson 30hp lower unit stuck
    By brandon51 in forum Johnson Evinrude Outboard Forum
    Last Post: 04-21-2010, 06:18 PM
  2. 30hp johnson lower unit
    By tal55lyd in forum Johnson Evinrude Outboard Forum
    Last Post: 03-07-2010, 10:36 PM
  3. 1956 Johnson Javelin 30HP
    By tac1120 in forum Johnson Evinrude Outboard Archive
    Last Post: 12-07-2009, 12:14 AM
  4. Replacing seals in lower unit 1956 30 hp johnson
    By wen4222 in forum Johnson Evinrude Outboard Archive
    Last Post: 11-30-2009, 01:19 PM
  5. 1956 30hp Johnson questions
    By James M Camp in forum Johnson Evinrude Outboard Archive
    Last Post: 01-20-2004, 06:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
