Results 1 to 4 of 4
  1. #1
    Join Date
    Mar 2009
    Location
    dhaka Bangladesh
    Posts
    30
    Default hi bought a seahorse 10 hp fo
    hi
    bought a seahorse 10 hp found the model number qd22s and sl number 2212944.
    anyone can tell the year of make ?
    thnx
  2. #2
    Join Date
    Oct 2007
    Location
    , ny, us
    Posts
    1,054
    Default 1961..The manual and parts are
    1961..The manual and parts are available on this site...Click on engine manuals and engine parts at the top of the page and plug the QD22 number in.
  3. #3
    Join Date
    Jul 2009
    Location
    Duluth, MN, USA
    Posts
    338
    Default It should use the modern style
    It should use the modern style single fuel line as well.
  4. #4
    Join Date
    Mar 2009
    Location
    dhaka Bangladesh
    Posts
    30
    Default "thnx to all , i already conve
    "thnx to all , i already converted the dbl line to single and changed the fuel line . engine started in first pull but it was deing after few seconds then i open the carbs and found some holes in flot and also found the flot pin without spring !! its sems the original comes with out spring coz there is no spring grove in the pin! should i change the pic or the old ill work?
    the present problem i am facing that the engine is rough .lots of ups and down in the race .suddenly goes ups and down. checked the butterfly and found ok checked the intake gaskit is also found ok.
    any idea what to chk more ?"
Similar Threads
  1. Fuel ratio of QD22s 1961 seahorse 10hp
    By knight1852 in forum Johnson Evinrude Outboard Archive
    Last Post: 12-14-2009, 04:41 PM
  2. Johnson seahorse 4 hp cant detemine the year model
    By mattwilldoit in forum Johnson Evinrude Outboard Archive
    Last Post: 04-26-2008, 01:55 AM
  3. Johnson seahorse 10hp
    By ted in forum Johnson Evinrude Outboard Archive
    Last Post: 10-24-2007, 07:57 AM
  4. 20 hp seahorse johnson need year and model
    By pamtimpam in forum Johnson Evinrude Outboard Archive
    Last Post: 11-14-2006, 04:42 PM
  5. Older Johnson Seahorse 35 model and year
    By David Drylie in forum Johnson Evinrude Outboard Archive
    Last Post: 04-28-2004, 06:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
