linkage on bottom carb on 2 stroke 90
mcatan2468
Can anyone tell me what the li
Can anyone tell me what the linkage is that is on the right side of the bottom carbuerator on 90 hp 2 stroke (2000) ? How should it be adjusted? I had to replace the nylon connector on the end away from carb but motor run at low speed but will not accelerate. Mike
"2000 C90TLRY I was wanti
"2000 C90TLRY I was wanting to know if what the linkage on the right side of the lower carburator is for. I had to take that carb off to clean it and the nylon connector on the back end of the linkage rod broke, so I had to replace it, but don't know how much to adjust in and out. Idle seems fine, but have no power to get up on plane. Don't know it this could be part of the problem. Mike C."
sounds like you broke the carb
sounds like you broke the carb lineage to adjust the sync and link
post a pic
